Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
How do I boot into utilities as my system is locking up
I turn my MacBook Pro on enter the hardware password and it gets to a gray screen with the indication bar full like it needs but it never gets to the desktop, it just sits there and no combination of keys gets it to do any thing. I am able to shut it off with the power switch.
On start up what is the key you are supposed to press to get into utilities to diagnose?
Is dit een goede vraag?
1 Opmerking
Does your system still have its original HDD or did you upgrade it at some point? If you did upgrade it what did you put in another HDD or SSD?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Press and hold "D" key after you power on the mac to load Apple Diagnostics.
Alternatively if you can connect to internet, press and hold "Option" + "D" key at the same time to load Apple Hardware Test.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
novosad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 28
