Ga door naar hoofdinhoud
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 Vragen Bekijk alle
Ipad 4 repair question.
I want to repair an ipad 4 lte, but I want to make sure I get the right part. I've tried re-booting it and these grey lines still persist, and the touch screen still works, so I need a new lcd screen, right?
Thanks for any help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Is this the only thing you see on the LCD? Logically speaking it should be just the LCD that is defective. However, if the iPad has been dropped a lot, had a recent repair or came into contact with water, it might be a bad connection or logic board related.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Yeah, it's only grey lines that show up, also I'm not sure if any of those things've happened to it.
door
Then the logical thing to try first is a new LCD.
door
Okay, thanks.
door
Voeg je antwoord toe
S Pin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 57
