Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
What’s with these blue lines and white bar on my 2Ds?
When I press the power button once the it turns off again with a popping sound
When I press the power button a second time it turns on skipping the safety and warnings screen that usually pops up
The top screen is black to about halfway down where approximately 10 blue lines with a sliver of black In between are present where another thicker bar starts which the color changes sometimes usually it’s beige or brownish
Then there’s a continuation of the other bar but a different color usually white or gray or both at the same time
There is one final blue line at the end
The remaining quarter of the top screen is black
Can anybody tell me what the heck is going on
Update (04/06/2018)
this is what it looks like
Update (04/06/2018)
It seems to be moving right now it’s starting to go away plz explain
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @mewash3re
Looks like the LCD module could be faulty, perhaps you can try opening up and reseat the connectors, and see how. LCD parts can try sourcing from ebay or aliexpress.
Nintendo 2DS Screen Replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Megan w zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 532
