Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
572 Vragen Bekijk alle
Is it possible to install an SSPOLARIS SSD drive in my 27" iMac?
I'm thinking about upgrading my late-2015 iMac with an SSD.
Currently it only has a 1TB HDD, I saw that apple now has these new SSPOLARIS drives which are way faster than the SSDs that were shipped with my iMac's generation.
I have the following iMac:
Apple Model No: A1419 (EMC 2834) Model ID: iMac17,1
I noticed that the SSPOLARIS drive has a slightly different form-factor but has the same socket.
From a compatibility standpoint, is it possible to install this SSPOLARIS in my iMac?
Is dit een goede vraag?
2 opmerkingen
One of these is your system: iMac17,1
door
Yes, the iMac "Core i5" 3.2 27-Inch (5K, Late 2015)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The speed difference has a lot to do with the width of the PCI lanes the newer systems support. Your system only has a PCIe 3.0 x2 SSD where as the newer Mid 2017 27" iMac's (iMac18,3) have a PCIe 3.0 x4 SSD.
Reference: The Ultimate Guide to Apple’s Proprietary SSDs. Sadly Cody has incomplete information on the iMac's and his section on the iMac (Late 2015) is a bit confusing.
You'll need to make sure you've got Sierra installed as it applies a firmware update. That should do it and then add in your new Apple blade SSD BeetsTech - Apple Solid State Drive (2TB) or if the 2TB drive is a bit to much for your pocket here's the 1 TB drive: BeetsTech - Apple Solid State Drive (1TB)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Randy Alvin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 920
