Ga door naar hoofdinhoud
De grotere versie van Samsung's nieuwste smartphone, de Samsung Galaxy S8 Plus. Uitgebracht in April van 2017.
Samsung Galaxy S8 Plus Broken Screen Data Recovery
Hi guys. I am wondering if there is a Samsung Galaxy S8 broken screen data recovery that can extract data from Galaxy S8. My S8 was dropped and the screen is not responsive now. How to extract the data?
Is dit een goede vraag?
Score 9
1 Opmerking:
U could try to see if u can plug in a mouse and monitor to type in ur passcode and backup the phone, however if u chose the encrypted option then it might not allow it to work and I'm not sure if u need to enable anything for it to recognize the mouse or monitor.
Other option is to fix the screen
door
Voeg een opmerking toe
4 Antwoorden
In order to extract the data from a smartphone, you need to go into the phone and enable file transfers. Unfortunately, you need a working screen for this. In a pinch, you can try:
  1. Replace the screen with a new one and perform the data transfer
  2. Download the files from cloud storage (hopefully you had data sync turned on)
  3. Download a free file recovery software (like “Recuva” or “Ibeesoft") to your computer, attach your phone via USB, and try to have the recovery software search your phone for files to transfer, if it can.
  4. Contact a professional data recovery service like Secure Data Recovery or Gillware.
Was dit antwoord nuttig?
I’m sure I’ve said this before but that program simply doesn’t work for a blank screen. It wants the phone in USB mode (if I remember correctly) and you can’t do that if you can’t see the screen.
Replacing the screen was NOT on the list of things to do. It cost too much.
1 Opmerking:
how did yo conected an screen. Im having the same problem here
door
Thank you, I finally made it.
I connected a screen to my samsung, the touch was still working so it was a werid way to fix, guessing keys to hit.. but now its done
thanks
1 Opmerking:
See above comment. If the screen is trashed, you can't see ANYTHING to be able to use touch (even if that was still working)
door
Unless you have those things saved to the cloud, you need to get into the system.
If you did have things backed up, it's way easier, just go to where you have your stuff saved and recover it. Google Photos and Drive work with iPhone, and you can get your contacts if you had them saved on some account as well.
Voeg je antwoord toe
Johnblack zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 30,641
