Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
MBP is down Pulled the plug from my iPhone and than it crashed
My MBP 13" Unibody MId2012 chrashed.
What happened:
Connected my Iphone 5s to the MPB via cable.
I got called and pulled the Plug.
Screen went black... Thought nothing.
After the call i wanted to get working again... Nothing.
STATUS now
First the Macsafe Light was barley to see ... Color Green
My Macsafe now is blinking Orange, fast like 3 times a sec
The Batterylights on the Left show nothing.
The Powerbutton is not responding.
MPB is not starting
no Sound nothing
It is 2 1/2 Years old, never dropped, never spilled anything on it.
Weird... Last one i got ten years until the Battery exploded.
Maybe it was the Taxsoftware that make it chrash...
na just kidding
Any suggestions.
Logicboard? DC Jack? Everything?
Would like to fix it
I am tired of buying new stuff
Cheers
PS: I also speak German and Spanish, if this helps. ;)
Is dit een goede vraag?
1 Opmerking
I also tried 3 different Chargers. All react the same.
Flickering Light in amber/orange
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The post: Not charging, blinking green/orange light could help.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Not quite sure about this, i read it some hours ago. But if the Ram reseat won´t work out. I´ll try something else. Thanks for the hint.
door
The Problem was solved by
- disconnecting the Battery
- with disconnected Battery i was able to power up the MBP via my MACsafe
Light was steady orange and bright
- turned of MBP
- making the SMCreset
- reconnected the Battery
works again
+ before that i reseated the RAM (2x8GB) as MR. MAYER recommended... so it didn't work straight away maybe it helped.
door
Het nuttigste antwoord
Reseat your RAM (three blinking lights).
Score 2
3 opmerkingen:
Aye Aye Sir, i will try that.
Thank you very much
door
I reseated the RAM and Symptoms stay the same.
Powerbutton not responding
MACsafe Light on the plug flickering orange
No Chargeindication Lights
door
MR. MAYER thank you for your suggestion with RAMreseat.
door
Voeg je antwoord toe
Jens Hindelang zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 70
