Ga door naar hoofdinhoud
The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
20 Vragen Bekijk alle
How do I fix the Charging Error?
My smart watch charges for about a minute then a message pops up saying "charging error", then the watch siezes to charge . How do I go about repairing that ?
Is dit een goede vraag?
Score 7
5 opmerkingen
Not open my smartwatch place open my smartwatch dz09
door
When my smart watch on it says in a few seconds later “Charging Error” .But when i shutdown it it takes a lot of time but not a charging error DIALOGE
door
Shut on hni ho rha automatic shutdown
door
My dz09 smart watch ka charging pin demeg
door
My watch not switch on not charge
=== Update (10/10/23) ===
My dz09 smart watch not on not charge
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Check the charging port to see if it has anything in it. It not the cost of repair is more than this watch is worth. I would just get anotherone.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
it looks like a common problem just keep unplugging and re plugging it in seems to work on mine ,also after watching a video on you tube it may be play in the battery so just pop a piece of cotton wool on top of the battery and put the back back on may solve the problem .
door
Voeg je antwoord toe
Joel Will zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 6,120
