answering machine does not pick up messages
Answerin machine is on, but does not pick up messages. The greeting on the machine is different from recording heard when calling from outside.!
Is dit een goede vraag?
Check the user manual to see if you have everything set up correctly.
Also, make sure you are dialing the right number.
Was dit antwoord nuttig?
turning the answering machine on off, changing record time/call times didnt work. I think i have fixed it. The answering machine needs to be turned on while there is an incoming call, when the phone rings press the “answer machine on” button and allow it to take the message. Now its realised its job and “should” work.
Ok I can do that
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 86
Altijd: 5,166
1 Opmerking
Hi, @shooshoo ,
What is the make and model number of your phone or attached answering machine?
The Uniden Dect 6.0 1760 and 1760-2 doesn't have a built in answer machine..
door jayeff
