Ga door naar hoofdinhoud
Pi-top is a modular laptop you build yourself. It’s a tool to help you start learning how to code, create devices, and expand your knowledge.
Where to get a Replacement Screen for the Pi-top v2
Where should I get a new screen for the Pi-Top?
Is dit een goede vraag?
Score 2
1 Opmerking
I also have a Pi-Top V2, an became very frustrated when the screen blacked out intermittently.
I found that the screen bezel could be snapped off with no damage. It not easy, but not that hard. I used a big, sharp knife in the tight gap around the outer edge to carefully pry the bezel up, all the way around.
When it was off, I pushed the spot at the bottom of the screen where the flexible cable connects. Screen has worked reliably since then !
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello,
Try sending a mail to Pi-Top support. They gave me replacement parts for free.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Joseph Wallack zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 945
