Shutdown code after sleep
Long story short, I had to disassemble the computer to reattach the display assembly, and since then I've noticed odd behavior. At first, when I opened the computer from sleep, it would either restart, or take a few seconds to wake up. When I checked the terminal/logs for the previous shutdown code, I was getting 0, meaning power lost. I took the bottom off, and reattached the battery. Since then, whenever I wake the computer from extended sleep, I will get the code 5, indicating a proper shutdown. I have wiped and reinstalled High Sierra and that has made no difference. Checking the logs before I did the reassembly, I don't see anything of the sort. Is this normal behavior, or is something wrong?
Is dit een goede vraag?
Check your battery using CoconutBattery How many cycles and the batteries levels
door Dan
@dan I'm currently at 569 cycles and 86% design capacity. I'm pretty sure the battery is not a problem, as it still lasts a long time, and is never dead when I wake it up.
door da stumer
Would this have anything to do with the standby mode that some Macs go into after a couple hours? The code only appears after the Mac has been asleep for a couple hours.
door da stumer
