Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
I cant take out the screws on the back
i was trying to fix my 2ds screen when it works but when i took the battery out i found out the screws were impossible take out
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It should be a standard phillips screwdriver. if the screws are not turning, they may be stripped, or you may be using a driver that is too large.
Nintendo 2DS Screen Replacement
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
yep,they are stripped :/ I was using a 000 Philips screwdriver
door
if you absolutely need to get them out, it will damage the frame, but you can use a cutting disc attachment on a dremmel to cut a slot into each of them, and use a slot driver to remove them.
door
thanks.that fixed it!
door
Voeg je antwoord toe
Matthew Pinto zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 1,750
