Ga door naar hoofdinhoud
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
78 Vragen Bekijk alle
Not charging or turning on
My JBL speaker has been working fine and now nothing lights up even when it’s plugged in. I’ve used 3 diffrent cables to try and charge it with they don’t make a difference. Nothing has worked and it makes me sad. I’ve tried resetting it and again nothing happened, so I don’t know what to do.
Is dit een goede vraag?
Score 2
4 opmerkingen
i fixed it,
you have to put
pressure on the flat cable that is connected with the "power button/LED/ JBL Connect Chip". Then you have to put a cable back in the usb chip
after that it should work again
door
And how do you do that?
door
all of you are wrong!!!,
Did you check the 5v on the usb type v8 line?
Did you check the 5v on the usb board?
Did you check the 5v get to IC charging?
Did you check the 5v get to Batery?
Did you check the 3.3v & 2.7v & 1.2v to the PMIC?
door
how do i check all these? is there a kind of tutorial?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If your JBL Flip 4 speaker refuses to turn on, see the JBL Flip 4 Won’t Turn On problem page for possible causes and solutions.
If your JBL Flip 4 speaker will not charge or won’t hold a charge, see the JBL Flip 4 Will Not Charge Or Won’t Hold a Charge problem page for possible causes and solutions.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Abigail J Rhea zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 3,151
