Ga door naar hoofdinhoud
The Moto G4 Plus is an improvement on Motorola's Moto G4. The Moto G4 Plus offers a fingerprint sensor, increased memory capacity, and an improved rear camera. Model number XT1642 and XT1644.
73 Vragen Bekijk alle
Device not charging. tried replacement
hey guys. i do charging port replacements on a regular basis. i have soldered on all models of phones dating back to the BB9900, so i can tell you after 3 ports, that it is not the port failing.
I have also ordered and replaced the battery resulting in the same failure.
i have scoured the board under a 10X microscope, and find no physical damage to board, or related components
The device says its charging, however, the % does not go up within an hour.
Is dit een goede vraag?
1 Opmerking:
i have the same issue
door
Voeg een opmerking toe
1 Antwoord
It could be that the device just cannnot detect any battery that is it is given. I'd suggest checking the connection when you connect any battery.
Was dit antwoord nuttig?
Voeg je antwoord toe
Scott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 430
