Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Modelnummer A1707. Deze MacBook Pro, uitgebracht in juni 2017, is voorzien van Kaby Lake-processors, tot de 2,8 GHz quad-core Intel Core i7-processor met Turbo Boost tot 3,8 GHz.
Not all of the trackpad is clickable
So ive noticed on my personal machine that i cannot click anywhere on the edge of the trackpad i have to click at least 1cm in from the trackpad in order for the force touch to even click, for example i cant even right or left click right in the corner this doesn't happen on the 13 inch im just wondering if this is normal as most of the time im using a bluetooth mouse.
Is dit een goede vraag?
Score 3
4 opmerkingen
You may need to visit a store which has one on display to verify. For some reason I think thats right the click area is not to the edge.
Apple is pushing to the touch mediphor like the newer iPhones. So now you press and hold to gain access to the right click menu.
door Deel
The MacBook Pro trackpad is not all clickable I have one. 80% trackpad is clickable.
door Deel
ah well I'm glad I'm not the only one I hope this might be fixed at some point now that I've noticed it, its really annoying
door Deel
@danj it happens with both left and right I just stated right as thats most difficult as you naturally click in the bottom right
door Deel
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
Check with Apple to see if this is covered under their new program.
Keyboard Service Program for MacBook and MacBook Pro
https://www.apple.com/support/keyboard-s...
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
i popped it into them today, they refused to do anything, i checked all the devices in the store and around 7 of them had the same issue however some of them didn't, at first i thought it was all devices.
door Deel
Contact Apple directly at 1-800 MYAPPLE
door Deel
I had the same problem.
Apple actually changed my trackpad/keyboard 3 times in a row before realising they couldn't do anything.
They then understood it was a broader problem affecting all new 15'macbook pro.
They explained to me that the haptic feedback does not cover the whole area of the trackpad. There is no fix.
Score 2
Compared to the ones I've seen in store, the whole trackpad should be clickable? Even if half of your finger is off one side, it should still be able to be clicked? I would definitely try and take it into a store if possible and compare/get them to repair it for you.
Score 1
1 Opmerking:
It appears on all or most of the 15 inches ive had the trackpad replaced twice and a new machine they say theres nothing they can do and its normal which it clearly isnt
door Deel
Voeg je antwoord toe
lewis Barker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 2,048
