Ga door naar hoofdinhoud
LG VX8550 is a cell phone that has both camera and media capabilities and features a new scroll wheel.
Cell phone, wont charge
MY CELL PHONE FOR SOME REASON WHEN I TRY TO PLUG IN THE CHARGER BECAUSE THE BATTERY WENT DEAD I HAVE TO WIGGLE THE PLUG IN THE PHONE TO MAKE A CONNECTION SO THE PHONE WILL CHARGE.NOW my battery went completely dead so i pluged in the charger now when i wiggle the plug to make a conection it wont at all now. i have to say i thaught it was the charger so the store i got it from one month ago they gave me a new carger but i still had the same problem only it wasnt too bad as long as i didnt let it go completely dead like i did this time.. i dont know if it is the phone wire port or the charger if any body has any advice i really would appreciate it thank you... JOE
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like the jack where the charger plugs in is either loose or has a short. I would take the phone in and have them check it. It has to be the battery or charger or phone jack and based on what you stated the problem looks like a loose connection.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I will add to that look for debris in the charger port and/or bent pins.
door
Voeg je antwoord toe
joe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 1,754
