Ga door naar hoofdinhoud
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Vragen Bekijk alle
Best battery adhesive removal?
Currently having trouble with battery removal of this phone. I would like to know if there are any highly recommended adhesive removal solvents, rather than heating up the battery and trying to use a pick for this device? I have seen on some video but can't remember which one it was, if someone could point me to the right video or solution I would appreciate very much :)
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Acetone or methanol will do the trick.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks for that, worked exceptionally well, I was abit reluctant on contact with the battery but after testing little bits it neither damaged the middle Frame or the batteries protective sleeve. Thank you very much for your wisdom! ( I have also seen a few of your other articles relating and am surprised I never followed through with it.)
door
Isopropyl alcohol with flexiable plastic card. Probably the best method for all battery replacements.
Score 1
Hi KmkZ,
I would recommend purchasing the official iFixit adhesive removal kit or refill for removing your battery. Just a few ml of this should do the trick in about a minute to minute and a half.
Hope this helps,
Tanner
iFixit Adhesive Remover Afbeelding
Product
$19.99
Voeg je antwoord toe
James zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 65
Altijd: 7,749
