Ga door naar hoofdinhoud
De derde generatie Audi A6-model werd in 2005 geïntroduceerd door de Duitse fabrikant. Gebaseerd op het C6-platform van de Volkswagen Group, beschikte de nieuwe A6 over dezelfde Audi-stijl single-frame omlijsting en een herziene wielophanging.
Audi A6 2006 suddenly stopped
My Audi 6 2006 suddenly stopped
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Since the symptoms are not clearly stated, it is difficult to point out the issue in the first place. It could be a bad ignition module or ignition switch. Sometimes the engine is absolutely fine but won’t start. In such cases, it would be best to leave alone for a couple hours and try again. Sometimes, the car would turn over but doesn’t start, eventually the engine would fire up. This means CAMSHAFT POSITION SENSOR requires replacement. However, to properly identify issue, it would be better to take your Audi A6 2006 to the nearby autobody shop in Greensboro.
Was dit antwoord nuttig?
The 2006 A6 is equipped with 347mm brake rotors, large calipers, and powerful vacuum boost. You will find that it has exceptional ability to stop suddenly even from very high speeds. To allow it to begin to move again after a sudden stop, release pressure on the wider foot pedal to the left within the foot well and begin to carefully apply pressure to the narrower pedal on the right.
Špatně palivo ,voda v naftě
Voeg je antwoord toe
Chris A zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 47
Altijd: 2,474
