Ga door naar hoofdinhoud
The fourth-generation Hyundai Elantra was released in 2006 for the 2007 model year. The Hyundai Elantra sold under the name Hyundai Avante in its South Korean home market.
14 Vragen Bekijk alle
Hyundai avante( elantra) 2007 kick when shifting from P to R
Hi All,
I have elantra 2007 and i have problem when i shift the gear from P to R or from R to D the car kicks once and the RPM will not exceed 2000 RPM this happens when i start the car. It's also happen when driving like 100 KM/hr the car also kicks and i can't exceed 120 KM/hr.
Hint : The gear is Auto
Is dit een goede vraag?
Score 1
1 Opmerking
You may also want to verify the transmission fluid levels, It may be that it is running low or needs to be changed. I have this car and for some time it would kick when shifting down in gears while in drive, or when shifting from R to D.
Once I filled the transmission fluid to the proper levels, the kicking stop immediately .
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Read about it here.From what I can read about your car. This is a very common problem though no recall at the moment. However what happens is your speed sensors in your Auto are failing and need to be replaced. The car then goes in to 'limp' mode to protect itself. Apparently the sensors are both inexpensive and easy to fix.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hi, I have a 2005 (1st gen) Elantra and I cannot engage the gear lever where it’s park in the garage ? Please assist ? Tq
door
Voeg je antwoord toe
omar almrsomi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 727
