Ga door naar hoofdinhoud
Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
56 Vragen Bekijk alle
What adhesive do I need for LG G6 screen replacement?
I purchased a replacement screen/digitizer for the LG G6. There doesn't appear to be any adhesive on the glass back or in the package. What adhesive should I use to install the new screen to get it as water tight as possible?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I used the below product and it worked great. Very thin, did not result in a 'raised' screen or back glass. Very sticky. I was careful to remove all the old adhesive from the inside frame bezel area for the screen. I also put several vertical strips beneath the screen to help.
Eco-Fused Adhesive Sticker Tape for Use in Cell Phone Repair - 2mm Tape - also including 1 Pair of Tweezers / Eco-Fused Microfiber Cleaning Cloth (black) $6.99
https://www.amazon.com/gp/product/B00BXY...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I'm not affiliated with the supplier. I just didn't get an answer, tried this stuff, and it worked.
door
Voeg je antwoord toe
Russ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,137
