Turn signal causing brake light to go out
Driver side brake light goes out when I use the left turn signal, it comes back on after I do the right turn signal then the left again. I replaced the brake light switch, flasher relay, and both back light circuit board and bulbs. Is it possible that it could be the turn signal switch on the column causing this issue?
Is dit een goede vraag?
