Ga door naar hoofdinhoud
Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
17 Vragen Bekijk alle
Why is my ABS and hand brake light on all the time? RESOLVED
Hi guys I would appreciate your help. I have a suzuki swift ZC31.the ABS and hand brake light is on all the time . How do I fix that?
Update (03/12/2018)
Apparently the ABS module had failed.And was swapped out with a junkyard replacement.
Is dit een goede vraag?
Score 3
1 Opmerking
My breaks ar light weight
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I had the same problem. I purchased a used ABS pump from a scrapyard and it solved the problem.
Use your smartphone to photograph the labels and numbers from the failed pump, to ensure that you get the right part.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Joseph Fernandez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 670
