Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
Using Suction Cup to remove screen with a screen protector
Can you still use the suction cup to lift up the screen if you have a glass screen protector (ZAGG) installed on the screen or will it lift off the protector?
Is dit een goede vraag?
Score 2
1 Opmerking
Thanks for the answer. Worked like a charm. Battery replaced in about 20 minutes
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You can use suction cups no problem but on cracked screens the glass tends to separate from the palstic frame if it is an after market screen.
I always use razor blade on sides of screen to lift it up after taking out the two pentalobe screws.
Was dit antwoord nuttig?
Score 4
Brian, you can use a suction cup to remove the screen. The screen protector won't come off
Score 2
Voeg je antwoord toe
Brian Thompson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 13
Altijd: 2,370
