Ga door naar hoofdinhoud
Dell Inspiron 15-3531 laptop with an Intel processor and a non-touch display.
14 Vragen Bekijk alle
My laptop is overheating!
My laptop is overheating. I have been told that I may need a new fan but I don't want to assume that's the only solution. What is something I can do at home before getting the fan replaced by a specialist?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Karen! The first thing you should do is make sure your laptop is not sitting on a bed or similar surface as this can block the airflow of the fan and cause your laptop to overheat. If your laptop still feels hot on a cool, hard surface like a desk or table, the fan might be either dusty or broken. You can try to clean the fan; however, if you are still dealing with issues, you may need a replacement fan.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Karen Wright zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 278
