Ga door naar hoofdinhoud
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 Vragen Bekijk alle
Left side of headphones is quieter
The left side of my jbl headphones is quieter after a fall...but when using the headphones.....when i apply pressure on the left earcups ..louder sound is heard than when not applying pressure...what can i do to fix this??
Is dit een goede vraag?
Score 2
1 Opmerking
Hence i tried findingpossible problems...but nothing..
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hi, I had the exact same problem.
The reason for this, was that I didn't properly connect the audio cord to the headphones. You have to push it in with greater force.
I'd be glad to know if this helped :)
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Actually the headphone is bluetooth and whether i use a cable or not same problem..;) i d be happy if u have another suggestion.. thx for the suggestion though
door
I have the same problem
door
I think it just broke a little bit but you can fix it by going into the settings of the device your using and change the volume in the left and right headphones
I had the same problem after a lot of a use (often out with my dog rainy nights, freezing temperatures in the winters, and such) and it turned out that the driver solder connections had gone bad. Resoldering solved the issue almost two years ago, still going strong!
Voeg je antwoord toe
Amir zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 69
Altijd: 3,793
