Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
iPhone SE mic and other issues
I have an iphone SE that I am having issues with that I hope someone can help me with. It was brought to me to try and fix. First of all, the ear speaker will not work at all, it will not switch over to headphone mode when you plug in headphones. Siri will not pick up your voice, when you open voice memos, the record and play buttons are grayed out and you cannot select them. Also, during a phone call you can't switch it over to speakerphone because the buttons are grayed out too. However, the speaker does work to play music or videos and system sounds. I've replaced both the front camera flex cable and the charge port flex cable with the same results. Do you suppose that There are motherboard issues or is it another part of the phone that I'm overlooking?
Thanks for the assistance.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
No dought that is the fault of audio ic
Was dit antwoord nuttig?
1 Opmerking:
So, is this an expensive fix? I know it involves microsoldering which I can't do. :)
door
Voeg je antwoord toe
Ethan Grier zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 161
