Ga door naar hoofdinhoud
Repair guides and support for the 5th generation Chevy Caprice. Manufactured by GM's Australian subsidiary, Holden.
3 Vragen Bekijk alle
What type of fuel shold I use for my Chevrolet Caprice 2002 V8 5.7 Let
Fuel type for caprice 2002 is it 87 or 91 or 95.
I live in Saudi Arabia we only have 91 and 95. What type should i use.
Update (03/04/2018)
What if i use 91 is it going to by problem,
Or only Performance will be weak.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Simply use this website from Aramco to determine the best fuel for your car
http://mycar.saudiaramco.com/start#/choi...
I have a 2004 Caprice LTZ and I have been using 91 without any issues
Good luck
Was dit antwoord nuttig?
If you open up your petrol flap it should be printed on the inside of that what to use. But if it is a V8 then 95 would be the best to use. If it is a V6 then either would be ok.
3 opmerkingen:
door
door
If you use 91, yes performance will be next to zero. 95 will give you better performance and better fuel economy. It may also ping, meaning it will have detonation issues. Best bet is to use the best fuel available and if that is 95 then use that. You will notice in the long run that you will get better economy with 95 than with 91.
door
Voeg je antwoord toe
Silver zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 407
