Crank shaft position sensor replacement
how do i change the crank shaft position sensor on a 1997 chevy cavilier 2.2
Is dit een goede vraag?
If you are facing the car the crank position sensor will be on the left side of the engine, down low on the crank case. It will be to the left of your oil filter if you are facing the left side of the engine. Crank position sensors are typically easy to unscrew and change. Be sure you create a good seal when putting the new sensor in to avoid vacuum leaks.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 686
