Ga door naar hoofdinhoud
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
20 Vragen Bekijk alle
My Sony PSP won't turn on even with power supply
The PSP won't turn on even with power supply, no lights nothing I cleaned the triger but Still nothing should I try bridging the tb fuse?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@lacasique old question and somehow it popped up ;) First thing I'd do is to replace the battery. It is definitely no longer holding a charge. Always look for the easy stuff first :) and than make sure that the battery makes good contact.The PSP has fuses on the MB. It has 2 fuses (LD) One marked TB. The other is located beside the power cable disconnect. check those for continuity. If they do not have continuity that means that they have failed (actually they have done their job and protected the board). Please do not just bridge fuses. There is a reason why your device has those. If anything should shorten your board out again, the damage will be somewhere within other circuitry and component repair will be needed. It just makes your job harder.
Was dit antwoord nuttig?
Score 1
Have you confirmed that the batter you have is good? If not I would check that first then move onto other possible solutions.
Voeg je antwoord toe
Jaqueline zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 342
