Ga door naar hoofdinhoud
Portable wireless speaker with a built in microphone. Released January 27th, 2014.
36 Vragen Bekijk alle
Can someone identify this component Please... A6 A
JBL Flip 2
A standard charging port replacement went south when the centre screw removed this component from the main board.
Its designation is D9 on the board and printed with A6 A, I believe its a Diode but not sure what other properties it has.
my knowledge on components is that of a three year old monkey.. I can replace and solder, but how or why it works is beyond me.. some sort of magic I presume..
Its situated next to the centre screw hole on the main board, and without this the unit wont turn on or charge unless you hold the power button down, when you release it, the speaker turns off with a loud pop..
Any help on this would be much appreciated..
Many Thanks
Paul
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Hey Paul,
I don't have this board but you're exactly right - that is indeed a diode. Diodes pass current in one direction and there are several types. Some google searching for A6 diode indicates that it could be a BAS16 or a BAV series high speed switching diode. There seem to be a few diode manufacturers / types using this code. Check with Mouser electronics or other supplier as they could probably help you find a replacement.
BAS16 datasheet
Was dit antwoord nuttig?
try something like this
https://www.digikey.com/product-detail/e...
make sure you get it in the correct direction
Voeg je antwoord toe
Paul Tulip zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 131
