Ga door naar hoofdinhoud
Repair guides for feature cell phones manufactured by ZTE. This category is for phones not using an Android or Windows operating system.
32 Vragen Bekijk alle
Why won't the SD card work when I need more memory?
Whenever I go to download a app it says memory full and that I have to delete other apps but whenever I check memory in the SD card it says I have room to download apps is something wrong with my SD card or my phone?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @bgranger ,
By default, Android downloads to the phone's internal memory.
You may be able to move the app to the SD card once it has been installed in the phone by going to Settings > Apps swipe to Downloaded then scroll down to find the app.
Tap on the app and check if there is a Move to SD card option available. If there is tap it and then follow the prompts.
Be aware that not all apps can be moved this way. It depends if the app's developer has enabled this when the app was first developed.
You can also clear space in the phone's internal memory by shifting your data (e.g. pictures, music etc) from the phone's internal memory to the SD Card.
To make the SD card the default write disk go to Settings > Storage > default write disk and select SD card.
This will only affect your data after you have enabled it. Anything that is already in the phone's internal storage will have to be manually moved over using the File Manager app.
be sure to only move your data and not any system files as this could cause the phone to stop working
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
That didn't work I can't move anything
door
Hi @bgranger ,
So no move to SD card option on any already downloaded and installed app then?
What model ZTE phone do you have and do you know the Android OS version (go to Settings > About phone)?
door
Voeg je antwoord toe
Brianna Granger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 76
