Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
Slow charging and sudden battery life loss
After putting off the upgrade for about a year and a half, I finally swapped out the battery in my early 2011 MBP with new stock from iFixit. The initial result was good: 6,058mAh through the first 3 cycles, per Coconut Battery. I did notice that it was taking longer to charge the computer, but I attributed that to the new battery's size - I was working with 3,528mAh (61% of original capacity) on 1,616 cycles before this new battery.
Couple days later, and I noticed two things. One, my battery capacity has already dropped off to 5,252mAh (91% of factory capacity) after 5 cycles. Two, my computer had charged maybe 20% over the course of 4 hours while on power adapter. Coconut Battery reported it was charging with about 3.66 watts. I have noticed this issue from time to time.
Do you guys think it's the new battery? The power adapter and cord? Or perhaps the MagSafe power port? My power adapter and cord is not as aged; I had to buy a replacement about 4 years ago. The MagSafe port is showing its age somewhat; it definitely doesn't look very clean. When I reset the connection, sometimes it'll jump to a higher wattage for charging (like around 12 watts). One last time I noticed recently was that the LED would slowly dim out once in a while - weird!
Answers greatly appreciated!!
Is dit een goede vraag?
Score 9
1 Opmerking
Hey Spencer,
Did the new battery solve your issues? Or did you have to get another battery from a different supplier? I'm on my second ifixit battery with the same issues.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Wound up taking my computer to the Apple Store since they had an opening. They will spend quite a bit of time giving you their disclaimer that they won't do any repairs for you since you've installed 3rd party parts into the system - ignore this. The battery replacement is a ridiculously easy job, and you don't want to be paying them to undo a couple screws anyway.
Anyhow, they ran a test that confirmed the problem was with the battery. It took maybe five minutes, and the same test also verified that everything else was in good working order (logic board, MagSafe port, charging adapter, etc). I also wound up getting my replacement battery on warranty from iFixit later that day, and the early returns on this new battery are encouraging so far.
Lastly, I want to add that I learned it's supposed to take about 4 hours for your MBP to fully charge from empty. The first 0% to 80% is done via "fast charging", and is supposed to take about 2 hours. The last 80% to 100% is done via "trickle charging", and is supposed to take another 2 hours. The whole point of this trickle charging is to avoid damaging the battery with overcharge once it's near capacity, and is a logical explanation why you'll have much lower wattage when charging during those conditions. I've verified this with constant observation using CoconutBattery, and my MBP now takes 4 hours or less to charge.
Hopefully this info helps everybody who came to this thread with a similar issue. Don't assume it's the logic board right away - that's a PRICEY part, and a hard fix, if I'm not mistaken. The Apple Store won't charge you anything to diagnose the problem, so take advantage of that if you can.
Was dit antwoord nuttig?
Score 9
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters see if your MagSafe adapter is the correct one and the connector interface is clean and in good working order.
Update (03/05/2018)
Sadly, it sounds like you have a charging logic issue within the system. Lets see if we can isolate the fault. Follow this IFIXIT guide MacBook Pro 13" Unibody Early 2011 Logic Board Replacement for the first four steps, once you disconnect the battery jump down to Step14 disconnecting the battery charge indicator ribbon cable place a piece of tape across the connect so the ribbon stays disconnected. See if that changed anything.
Score 2
3 opmerkingen:
I know the adapter is the correct one, because I purchased it from Apple. The interface also looks fine based on the pictures.
door
So you didn't double check to be doubly sure ;-} Even the Apple sales folks make mistakes. Which is why you really should check.
In case you missed the link in the first Apple T/N heres the follow through: Find the right power adapter and cable for your Mac notebook
door
Actually, I did double check. I wound up getting an appointment to the Genius Bar at one of the Apple Stores in my area, and they confirmed it was the battery. The test they ran also showed that everything else was working fine.
door
I’m having your same original problem. And I just bought MBP 13 in June - about 4 months ago. But I use excessively all day doing cloud computing database work, and evenings watching YouTube movies whatever. That battery is like 4 years old in battery years since it’s been working 16-20 hrs a day for 4 months. If there’s a chance this level of use will ruin my system beyond the battery - I better find out now b4 too late.
THANKS this was very helpful. Heading to Apple store for a level 5 diagnostic. Lol #trekkie
Voeg je antwoord toe
Spencer Wen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 34,094
