Ga door naar hoofdinhoud
The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
Rear Brake light is out and its not the bulb.
Rear Brake light out and both brake a front blinkers work on and off with the light flickering fast when it does work. Help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
OhhhK. When your indicators flash fast, usually that means that one has blown or has a fault. Or it could be your indicator relay.
If the rear brake light is out and it isn't the bulb, then it can only either be a fuse, relay or wiring. I'd check your fuses first.
Was dit antwoord nuttig?
Voeg je antwoord toe
Alison McCaulley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 244
