Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Vragen Bekijk alle
Read Hard Drive 128GB Samsung 1.8" Sata LIF
My 1st Generation Macbook air has died. Overheated fault on the main board. Power Loop issues. I have retrieved the hard drive out of it.
How do I read it.
Get an 1.8" enclosure?
What do you suggest any links?
What's the difference between ZIF & LIF?
What the easiest cheapest just want to wipe the drive & put it back into
sell the parts on.
Update (02/21/2018)
Is this drive enclosure the thing to buy?
Amazon - DELOCK Gehaeuse 1.8 micro SATA USB 3.0
Delock Product Page - Further Specification.
Can anyone confirm? It looks like it can do the job.
Is dit een goede vraag?
4 opmerkingen
Hi Jason, did you find the enclosure for the 1.8” SATA LIF? I have the same hard drive removed from Mac Air. Thanks
door
Mine had a Samsung drive in it. 24 pin LIF. Most are 40 pin. You have to be super careful to get the correct one. https://www.ebay.co.uk/itm/KALEA-INFORMA...
door
thank you. I will have a look at this :)
door
Did you manage to do this?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
ZIF and LIF use the same cable.
The difference is the way the connector locks onto the cable.
This old thread should give you a better idea what you want.
HDD to SSD
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jason G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,062
