Ga door naar hoofdinhoud
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Vragen Bekijk alle
Why does my ibook crash in Safari?
I am using OS X 10.4.1.1 Safari unexpectedly quits after about five minutes every time? Any ideas what this could be? I have downloaded all the software updates but this has made no difference?
Is dit een goede vraag?
Score 1
3 opmerkingen
Hi, right the mac is now crashing randonly after about 10 mins, I get the grey screen with the please restart your mac sign. It is not overheating as I have a temp monitor installed and it is in the 25-30 degree range when it crashes.
== Update ==
The problem was faulty RAM.
door
Could be a logic board problem now :(
door
Fixed it! It was faulty RAM
door
Voeg een opmerking toe
9 Antwoorden
Gekozen oplossing
Sorted it, the problem was faulty RAM although it did not show up on the Hardware test, when I swapped the RAM out for a different chip all the crashing stopped!
Was dit antwoord nuttig?
Score 2
1 Opmerking:
It's interesting, because a Powerbook G3 I'm fixing as a pet project is showing the same behavior. I "fixed" it by using Camino, but I'll rummage in the old ram bin. Belated plus one for your creative research and nice approach at the issue.
door
Het nuttigste antwoord
Hi! I'd remove the battery, Airport, and extended memory, and then reset the PMU and PRAM, and see if the behavior is any different before putting parts back in.
Does the laptop's video ever become distorted or go blank? Random freezing is a symptom of the G3 video chip issue, which is a logic board flaw with no reliable fix, and if the above doesn't help, I suspect you probably have a logic board issue.
There's a slight chance you could have a bad hard drive. To test for that, use target mode to boot from an external hard drive or another Mac, and see if the problem persists. Do all testing with unnecessary parts removed from the computer so they do not complicate the test results.
Score 3
Try reinstalling Safari, if that doesn't work, try reseting Safari. Also, what are you doing when it crashes? Anything flash? Or just normal web browsing?
4 opmerkingen:
I was looking at the ifixit web site!
door
So did you try any of my suggestions?
door
I did reinstall safari, but I am still getting the same thing,it does seem to be completely random ad or flash related as it crashes on non flash sites as well
door
You may want to check this article on resetting safari, it's known to work on strange situations.
Also, check Console for the logs to tell you what happened right before the crash, also check activity monitor for memory spikes, going off of what QEII suggests.
door
If you are using Safari 4, I suggest you go back to Safari 3, these older macs can be very slow running software at the edge of their compatibility. Safari 3 can be found in Apple Support.
8 opmerkingen:
I am running 10.4 on this mac so I am only using the safari that was bundled with it.
door
You could always try wiping your hard drive and doing a clean install of the OS. It would take some time, etc., but at the end of the day it may be the more efficient means of dealing with the problem.
door
This is the thing, the HD has been totally wiped and 10.4 re-installed and updated using the software updater, there is nothing else on this mac, it has got me stumped, ideally I would like to use safari as I cant stand using firefox
door
Has it been wiped and a clean install applied, and the problem occurred again a second time, not just the first instance? I'd put in different RAM, then reset the PMU and PRAM. If all else fails, there's always Google Chrome.
door
It has been wiped clean twice as well as the PMU and the PRAM being reset which made no difference.. oh btw Google Chrome doesnt work on 10.4!
door
3 commentaren meer tonen
Try disabling Java. It seems to crash my Safari after the latest Java security update.
Go to: Safari -> Preferences -> Security and uncheck 'Enable Java.'
If that doesn't work, you can also try unchecking Plugins and/or Javascript -- which unfortunately, is needed for a lot of websites but you can at least get an idea of what's going on!
For what it's worth, I've had trouble with Safari on a G4 iBook -- it wouldn't crash the way it does on your system, but it seemed really slow. I've ended up just using Camino instead.
1 Opmerking:
door
Thank you for the sugestion on disabling Java.
How do I get an older version of Java?
Do I really need it?
Model: PowerBook6,5, BootROM 4.8.7f1, 1 processor, PowerPC G4 (1.2), 1.33 GHz, 1.25 GB
Graphics: kHW_ATIrv280M9PlusItem, ATY,RV280M9+, spdisplays_agp_device, 32 MB
Memory Module: DIMM0/BUILT-IN, 256 MB, built-in, built-in
Memory Module: DIMM1/J7, 1 GB, DDR SDRAM, PC2700U-30330
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x4E), Broadcom BCM43xx 1.0 (4.170.25.8)
Modem: Jump, V.92, Version 1.0
Network Service: AirPort, AirPort, en1
Parallel ATA Device: MATSHITADVD-R UJ-825
Parallel ATA Device: TOSHIBA MK6025GAS, 55.89 GB
USB Device: USB OPTICAL MOUSE, (null) mA
I highly recommend you try TenFourFox. It is the most advanced browser for PowerPC (your iBook). Check it out:
http://www.floodgap.com/software/tenfour...
Score -1
1 Opmerking:
The Question was solved ''Jan 19 2010
1:11 PM''
door
Voeg je antwoord toe
thefax zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,326
