Ga door naar hoofdinhoud
Amana Refrigerators are manufactured by Whirlpool Corp group, in Amana Iowa.
23 Vragen Bekijk alle
Amanda (Whirlpool) fridge/freezer. Fridge quit
I have a 12 year old Amana (Whirlpool) fridge with bottom freezer. The freezer is working fine, but the fridge will not cool anymore.
Model AF B2234WES0. Any help would be greatly appreciated!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Cause 1
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks! # 2 & 3 are out. Fan and damper are both operating. I just looked under the freezer and everything is absolutely caked with dust. Going out of town tomorrow morning so will shut it down, clean it and try your #1 tomorrow night. Much appreciated!
door
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 258
