Ga door naar hoofdinhoud
Made in three sizes. The spin brush is identified by the serial number BC178RBCR.
5 Vragen Bekijk alle
My air brush doesn’t spin.
Hi,
My Conair pro airbrush turns on but doesn’t rotate.
Please guide me on how to fix it thank you.
Thank you
Is dit een goede vraag?
Score 7
4 opmerkingen
I had the same issue with the two I have had. It’s so frustrating
door
I gave the "neck"a little twist to the right and that got it going
door
I have the same issue too. When traveling Norway, my Conair rolling hair dryer had much more power and heat than when home in the US. It was faster and wonderful, but it quit rolling on day 2.
door
I fixed mine through determination. Mine had 2 tiny caps on the side of the upper handle. After I managed to pry them off I found two screws. Undid those and the brush came off. There is a very s air rectangular shaft inside and I think it had come unlocked. Tried it before I put tiny screws back in. It is working fine now. No, the top cap does not come off mine. Turned out to be a simple fix if you can get those two tiny plastic caps off.
door
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
It is probably stuck with hair.
Twist the top cap counter clockwise just a bit to unlock it.
Remove the cap and remove any hair.
If you unscrew the the small bolt on the top, you can remove the brush and take away the remaining hair.
It started spinning slowly, I let it spin for a couple of minutes and It started working again.
Was dit antwoord nuttig?
Score 1
8 opmerkingen:
It doesn't spin looks to be jammed or he left right spinning buttons are not working. How to open open them?
door
how to take off motor plastic case?
door
That is my question too. The cap doesn't budge for removal.
door
the cap is stuck on how do I get it off? It will not turn counter clockwise or clockwise.
door
Having the same issue and can’t remove the top cap
door
3 commentaren meer tonen
My conair won't go to hi. Just low feature. Is it supposed to do this?!
Sorry my doesn’t spin either. Just bought it threw the receipt out before trying, stupid I’ll never do that again
I have bc178 for about 4 years of not heavy use and from last year randomly it won't spin until I help turning it by hand than it start strong without stop unless I changed the rotation.
Now it becomes very weak and lost it's torque.
I disassemble it and there where no hair involved.
For disassemble in below order,
Two black cap for screw on base of brush and the two screws, brush, the black plastic ring at where brash attached to body, air intake cap and ring, cord ring, cord, black piece that main key is on it by poping it from cord side. Than the rest separate into two.
The motor is 24v brushed equipped with a gearbox. Quick search find it only on Alibaba and not selling for consumers.
Need to redo the soldering and loose two screw on motor housing to remove the motor assembly from heating element.
Didn't find and cosmetic damage and discoloration on electronics.
I am thinking of both bad diode that kill the current at motor and the motor brushes. Than the short brush doesn't have anything with low torque.
I gave mine a little twist at the neck and that got it going again.
1 Opmerking:
It's gonna take about hundred neck twist to call it dead.
door
Voeg je antwoord toe
Shirini2@gmail.com zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 149
Altijd: 6,575
