CPU Upgrade from A6 to A10
I have a new A10 with compatible pin config.
But A6 is glued to board -- will glue gun damage board? Other options to remove glue?
Is dit een goede vraag?
I don't think the CPU is glued to the board.
Rather, I think the CPU is Soldered to the board.
If you are comfortable with soldering, you need to remove the solder from hundreds of pins and make sure the new one aligns perfectly, and that none of the pins are blocked, damaged, or blocked.
Also, the HPs BIOS needs to have information in about the A10 in order for the CPU to work, even if the pins align.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 183
2 opmerkingen
It is clearly glue -- it is only on the four corners, it is clearish, and I have been slowly slicing away at it with a razor. No signs of solder yet...
door J.J. Lukas
Ok, well if its glued on, its a highly resilient epoxy considering CPU temperatures sometimes reach 85 C (185 F).
door S W
