Ga door naar hoofdinhoud
iPhone 7 Loud static and clicking noise on the recording
Everything went well and smooth on installing screen, but when I started testing my iPhone it seems it has some sort of interference when using the front and rear recording camera. All my recordings come out with a pretty Loud static and clicking noise on the recording . Is it possible that the screen is interfering with my Front and rear camera mic? Can someone help me out please?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Actually, iPhone 7 has four mics: one at the earpiece, and two at the bottom of the phone on either side of the lightning port, and one in the back between the True Tone flash and iSight camera. From what I've read, all are used for noise cancellation but the phones use the closest mic to any sound for clarity. For recordings in stereo (for those with iOS 10 or later), two mics are used for recording sound. Have you tried recording a voice memo to see if it happens there as well?
I suggest to also check the areas on the logic board where you connect the cables. Even the most experienced repair person can pop off/damage one of those nano-resistors or jumpers when unseating cables. I've done it a few times myself and it has taken my very strong and trusty magnifying glass to notice that. Very frustrating.
Good luck.
Was dit antwoord nuttig?
5 opmerkingen:
Hi there . I’m not really sure it’s the logic board connector because this only happens when I’m using the front camera. When I use FaceTime and try to do simple voice recording the strange noise doesn’t appear, beyond that the noise gets worse when I put my phone next to lightbulbs or switches. I bought my screen hearing in iFixit but Europe because I’m from Portugal, I sent them an email explaining what happened and they don’t seem to care they haven’t even returned my email.
Thanks for your help
door
hey man. i have the same issue. if you have found anything shoot me an email at da_pap@hotmail.com. I have ordered a new screen with an earpiece. The front mic is together with the earpiece so i 'll change it and see if that fixes the problem.
door
I’m having the same issue! Apple seems to think my mic is dirty... my phone has always done this and I want it fixed!!
door
hey, I'm also experiencing the same issue on my iPhone 7 when I record video with the front facing camera and sometimes with the rear. I'm really concerned if it's a software or a hardware issue, anyways if you find a solution or something could you please notify me as well? My email is e.tsigelis@icloud.com
door
I found when I have my iPhone SE2 sitting on its charging stand and connected to power when I record a voice memo, it plays back a background ticking noise but when its not connected to power, it works fine.
door
This could be because of the wifi signals interfering with the microphone.
You can try to turn off the wifi while you are recording something.
I hope that helps.
I’ve tried it both ways: WiFi Off & On. Still clicks.
Replacing the front camera resolved this issue.
Voeg je antwoord toe
lmatiasjr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 17,693
