Ga door naar hoofdinhoud
The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
28 Vragen Bekijk alle
My left wheel is making a noise when I drive more than 20mph
I ran over a speed bump and my left wheel is making a noise like it's rubbing against something when I drive more than 20mph
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Could be it's got a dent in the wheel now? If you can get it off the axel easily enough it might be worth a look. I hit a pothole once and it was a bit like that.
Was dit antwoord nuttig?
Score 2
As Jack said, it could be a dented wheel, or the knuckle joint could be damaged (worst case scenario)
Voeg je antwoord toe
desrick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 187
