Ga door naar hoofdinhoud
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Vragen Bekijk alle
lower case blocked screws removed
Hey!
I m trying to replace the original RAM of my new MBP following your guide.
Next removing the screws, the lower case can't be removed cause something keep it to the body.
have you got any solution for me ?
i'm afraid by braking something when i can't see where is the problem..
sorry for my poor english,
best regards,
David
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
As long as all the screws have been taken out, you should be able to just pop the lower case off its retaining clips by pulling it away from the machine near the vents.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
hi,
thank you, i managed successfuly to remove the back panel.
there was a sticker, and next reading few minutes a flash video, it was easy to remove :)
good job,
best regards
door
Voeg je antwoord toe
david zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 1,360
