Ga door naar hoofdinhoud
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Screen goes extremely dim
My screen is almost always extremely dark (no icons visible just very dim light) sometimes it helps to hit it on the back a few times for a few minutes but then it goes flickering/ green to black again. I also tried reset and completely reinstalling it without luck. I guess the LCD cable is loose? How much would a repair cost?
Edit: sounds like a backlight problem according to a local repair shop, he said repair costs 120€... is it possible to fix it by myself, without technical super skills?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Depends. It could be the LCD going out (which is a DIY) or a backlight coil, which would need micro soldering.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for your answer! "LCD going out" means I have to buy a new LCD screen for109$ ?
I wonder if I could fix it somehow with a harder hit on the side as the screen works perfectly sometimes...
door
You should have a warranty from your supplier.
door
It is better to fix it hitting it just rigs it to work for a while just replace it alway the way to go. And how about having the lcd tested on another I pad this will help diagnose what the issue is!
If you have any questions or concerns please comment below. Thank you
Score 1
Voeg je antwoord toe
Bastian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 33
Altijd: 482
