Ga door naar hoofdinhoud
The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
28 Vragen Bekijk alle
Why is my car rpms fluttering in between 1000 and 1500
I have a 2008 bmw 335i and it is fluttering from 1000 rpm to 1500 rpm
It started after I attempted to clean my intake valves.
Codes are
P1417
P1632
P1638
P11:
P1639
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Have you replaced your spark plugs?
Was dit antwoord nuttig?
2 opmerkingen:
Before the valve cleaning I replaced spark plugs ignition coils and fuel injectors
door
Ok, well unfortunately that's all I got. I've just had some experience replacing spark plugs that were causing the engine to stutter a bit.
door
Voeg je antwoord toe
Melech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 600
