Ga door naar hoofdinhoud
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
iPad4 microphone not working
I have an iPad 4 on which everything works except the microphone. I leapt to the conclusion that it was a broken microphone, ordered a new one, and replaced it. That did not solve the problem. Everything else on the iPad works fine. I've tried a soft then a hard reset but to no avail. It is running iOS 10.3.3 Has anyone run into this problem before? What are the odds this is a software problem?
Is dit een goede vraag?
2 opmerkingen
I tried a restore from DFU as suggested here Stuck in Headphone mode.. but that did not solve the problem either. Very odd.
door
Plugging in an external microphone/headset works just fine. At this point wondering whether the iFixit replacement microphone may have been defective.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The replacement microphone may be defective. Small parts have a higher failure rate, although iFixit is good with QC. Perhaps the issue is with the "hole" in the housing. It may be clogged up with dust/lint etc and that may be causing the issue.
The problem may also be on the Headphone Jack board (see this guide). Perhaps the connector is damaged on the board or on the flex side of things.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks for replying. The microphone hole was the first thing I checked. I am curious about your suggestion that the Headphone Jack board may be at issue. A headset microphone connected to the headphone jack works fine. Are you suggesting that the board may be interfering with the main microphone?
door
No, it's just that the microphone connector is on that board.
door
Voeg je antwoord toe
Steve Song zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 26
Altijd: 289
