Ga door naar hoofdinhoud
Second generation of the Acura TL.
10 Vragen Bekijk alle
Car not reversing after removing battery
My 2003 accura stopped entering reverse after a friend used my battery to help someone. The problem was fixed only for it to resurface again but all other gear selectors are working fine. Advise needed urgently please.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I would try resetting the car's computer through removing the battery negative terminal for around 10 seconds. If that doesn't resolve the issue, I'd take it in to a mechanic (or auto parts store) to have them check for error codes via the OBD2.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks mate it worked once more thanks you are one in a million.
door
Voeg je antwoord toe
attom garba zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 113
