Overheating, Water not running thru
I have a 96 Toyota Camry 2.2L , I have changed thermostat , ecu coolant sensor , radiator fan sensor switch , temperature gauge , and also it all started after I replaced the 2 O rings on the filter for filter coolant but the 2 hoses are good water pump good. Fan takes a while to cut on but they work radiator still good but water doesn't stay in , eventually it'll steam out or throw out coolant water. I'm out of options so if you know something else that be great or if other with same issue please help.
Is dit een goede vraag?
