Ga door naar hoofdinhoud
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
My laptop won't turn on
My laptop won't turn on. When it is pluged in only the little power lite comes on. And when I hold power button it makes beeps.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @matinr1
Here is a list of the "beep error codes" for your laptop.
When you turn on the laptop, count the number of beeps. They will occur in a repeating fashion with a pause between each set, e.g a 4 beep error code will sound like, 4 beeps -pause-4 beeps pause etc.
The code chart will give the reason for the failure and below that there are some repair options for each error code.
Hopefully this is of some help
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Martin Ramirez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 564
