No backlight with blown fuse under lvds connector
Good day
i have thinkpad x1 gen2 with black screen, i can see faint image with torch and external display works fine, i disassemble it and saw a blown fuse under lvds connector on main-board, i replaced it with same fuse and it blown right away after single test, there is an 8pin IC next to the fuse which i believe to be for black-light or something which is not good i think, i want to replace it but i can not read its number so i can order it, will someone help me identify this IC,
Thanks
Is dit een goede vraag?
1 Opmerking
I found Fuse 1 blown replaced it .
the Fuse is on the opposite side of the motherboard where the screen connector to motherboard is , it is covered in sticky protective plastic.
unfortunately to me the laptop stopped powering on something else has happened to it that I could not fined yet.
Power starts green light flashes then the fan starts then power off follows
door h.abboud
