Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Vragen Bekijk alle
Change SSD on iMac 5K Late 2014- 250GB SSD to 1TB SSD Sata
Hello,
in march 2015i bought iMac 5K with SSD 250GB. Model: APPLE SSD SM0256F
Recently i have an Samsung SSD 850 Pro 1TB SATA III, and my question is:
Can I instal this SSD Sata on my iMac? It is possible the both drives? ( Ithink APPLE SSD SM0256F is an m.2 Drive). If it is possible mount the the drive i will improve the HD speeds?
Thanks in advance!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hello,
yes you can upgrade the storage by simply buying 2.5 inch to 3.5 inch disc tray and mounting that instead of the hard drive down below.
https://d3nevzfk7ii3be.cloudfront.net/ig...
https://www.ebay.com/itm/2-5-inch-to-3-5...
Hope it helps
Was dit antwoord nuttig?
Score 1
Sorry, but i don't have the fusion drive 3.5. I bought iMac with SSD 250GB built in( APPLE SSD SM0256F). And i am not sure if it is a M.2 Drive. My question is can i install a new SSD SATA 3 (Samsung 850 Pro) on my mac? if it is a M.2 built in, can i run SATA3 new drive + M.2 drive?
I Call Apple and with my serial number they don't have sure if it is m.2 or Sata 3 inside.
Or its better buying an Thunderbolt enclosure to my Sata Samsung?
Can somebody help me?
Voeg je antwoord toe
Joao zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 481
