Ga door naar hoofdinhoud
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Vragen Bekijk alle
Software for transferring data between replacing hard drives
I am going to put in a new hard drive but i do not know how to get the info for my old hard drive to the new one. I thought i might have seen it on the sight but now i cant seem to find it. When i transfer the data will all my downloaded applications go with it thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You'll need a external hard drive adapter or enclosure to hook the new drive up to and format it, then use SuperDuper to clone it>http://www.shirt-pocket.com/SuperDuper/S...
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
when you say a external hard drive adapter, a external hard drive? and then copy the current drive in my computer to the the external one using SuperDuper then instal the new hard drive and the sync superduper?
door
You have to have a way to talk to the new hard drive and at the same time use the current drive. This can be done by using a adapter such as this one: http://eshop.macsales.com/item/Newer%20T...
or an external enclosure to put the new drive in, such as this one: [gekoppeld product ontbreekt of is uitgeschakeld: IF107-097]
If you use a firewire drive you can also boot from it.
door
Voeg je antwoord toe
eweirick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,030
