Ga door naar hoofdinhoud
Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
32 Vragen Bekijk alle
How to remove motherboard Anfang fix battery connector
I had the same problem as many others with the flickering, rebooting, not charging of the galaxy note pro 12.2 wifi. So I opened the back cover of the tablet and found the battery connector sitting in place but loose. When I touched it a bit too hard it moved and when I tried to push it back it fell apart. Now I have to replace it completely but can find No information on removing the motherboard. I did find a really good video on your website for the 10.1 I believe but my motherboard has a couple of more cable ribbons attached and I am not sure how to remove them.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Here is a guide on replacing the battery if that helps.
Here
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks but I am looking to replace the battery connector and have to remove the motherboard from the tablet to fix it.
door
Voeg je antwoord toe
Wayne De Groot zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 741
